نظيف علي
2023-11-19 18:59
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
أحمد حافظ
أحمد حافظ2024-02-01 02:27
Is it a resonance issue? Check the underbody shield.
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
What's causing the noise when accelerating in a 2015 S5 with manual transmission, when the RPM doesn't match?
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
