علي مكي
2024-05-08 21:59
The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
أحمد منذر
أحمد منذر2024-05-11 20:53
I had this issue before. Tried checking and replacing everything, but the fault codes kept appearing irregularly. The problem was solved by replacing all four fuel injectors.
سلمان زين
سلمان زين2024-05-11 01:07
Try disconnecting the negative battery cable for a few minutes and then reconnect it. It could also be an issue with the fuel you added.
Fuel not getting through, no power, engine warning light is on. What's the situation? Is it the fuel injector or the catalytic converter?
Has anyone experienced the engine warning light flashing and the vehicle shaking? It gets better after a while.
14 model Middle East Land Cruiser has driven 150,000 km. Recently, when starting in the morning, the center differential lock light flashes. After driving for a while and restarting, the light stops flashing. Just completed a full maintenance and changed all oils and fluids. Has anyone else experienced this issue?
The 4LO warning light and the engine light on the Land Cruiser are both flashing.
The car is a 2015 model and has run 99,000 kilometers. The warning light turned on, and you replaced 4 ignition coils and 4 spark plugs. After some time, the light came on again, and the engine shakes when starting, but it's still drivable, though the light remains on. What's causing this issue?
Can someone please teach me how to disable the sound that occurs once after locking the car, and how to turn off the hazard lights that flash for a period after turning off the engine?
When starting the engine, the malfunction indicator light flashes briefly and then goes off after starting. What could be the issue?
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
