سعود أبشير
2024-01-18 15:51
It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
When the 2018 F150 XLT makes a rattling noise when you release the accelerator while it's cold, but the sound disappears when the vehicle warms up, it could be due to several reasons. Since you've already replaced the timing components and the turbo, you might want to check other areas such as the exhaust system, heat shields, or engine mounts for any loose parts or issues. It's also advisable to consult a mechanic to diagnose the problem accurately.
Possible reasons why your car might not move when you accelerate could include: 1. Transmission issues 2. Low transmission fluid 3. Clutch problems (for manual cars) 4. Brake system issues 5. Engine problems It's best to have a professional mechanic check it out to diagnose the exact issue.
The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
When the MINI is in D gear and you brake, if there's a prompt to shift the transmission to P gear, there might be a couple of reasons for this. It could be an issue with the gearbox or a safety feature that's activating. If the car doesn't move when you release the brake, it might be due to a malfunction or an electronic system engaging to prevent movement. It's best to consult the vehicle's manual or contact a professional mechanic to diagnose the issue accurately.
It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
