فهد عباس
2024-05-11 19:50
I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
عبدالرحمن أم
عبدالرحمن أم2024-05-18 10:32
You should just buy an '18 model.
حسن حمدان
حسن حمدان2024-05-13 06:42
When starting the car, check if the battery is strong. A normal battery should work efficiently. If it feels weak, it's likely deteriorated.
حسن وحيد
حسن وحيد2024-05-12 09:26
The battery might be old. Try replacing it with a new one.
What could be causing starting difficulties, where sometimes it takes two or three attempts to start?
My car has a weird problem. Sometimes it takes two tries to start. What could be the issue?
Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
In the past month or two, my Vitara has experienced difficulty starting on two occasions. It takes several attempts to get the engine running. What could be the reason?
I have a 2016 Honda City, and sometimes it doesn't start on the first try, but it starts on the second attempt. Experts, what could be the problem?
Why does it take two or three attempts to start the car?
I have a 2014 Honda City automatic. Recently, I've been having trouble shifting from neutral to drive (it can shift, but not smoothly). Other gears are fine, and this issue just started a few days ago. Does anyone know what's going on? Looking for expert advice!
Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
