صادق نايف
2024-09-29 15:35
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
عبد العزيز أمينة
عبد العزيز أمينة2024-09-29 16:20
It costs just over 100 bucks for one time, not expensive.
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
Does the 2023 RAV4 still have rear tire wear issues?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
