محمد تركي
2024-04-24 19:16
Does anyone have a video on disassembling the gear console of the new Honda City? I'm planning to replace the gear light myself.
Why did the engine warning light turn on and the D gear light keep flashing after driving my 2014 Honda City automatic on the highway for three hours?
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
Hi everyone, what model and size of tires are you using for your City? I'm planning to replace mine soon, any recommendations?
Where is the cigarette lighter fuse located in the center console of a 2010 Honda City?
Is the Honda City good to drive? I'm planning to switch.
How do I use the hill climb gear in a 2012 Honda City automatic?
To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
Should I replace the battery at the 4S shop or do it myself? I'm torn.
Is 600 expensive for replacing the central control unit in a 2017 Honda City?
Honda Honda City
Honda CityAED 67,900 ~ 75,900Gasoline
