What should I do if the brakes make a squeaking noise? Is it necessary to replace the brake pads? The car is new, just bought four months ago, with over 4000 kilometers.
What could be causing a squeaking noise when lightly braking?
Has anyone experienced a whistling noise while driving the all-electric Lavida? Not sure what the reason is. Could it be the brake pads? But it makes the sound even when I'm not braking. It comes and goes.
4When braking to a low speed, there's a metallic noise. Does anyone know what's going on??? The brake pads were just replaced two or three months ago.
5Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
6The engine of the 2014 GS5 is making a squeaking noise. What could be the problem?
7Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
8Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
9When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
10Has anyone experienced this? The X90plus's wipers make a squeaking noise after only six months?
