Is the micro switch for the 2023 model really that prone to breaking? Just a bit over a year and the driver's side window is already not working, and I don't even use it often.
The materials feel quite poor, especially the window lift switches, which are prone to breaking.
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
4Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
5The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
6After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
7When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
8Today, I suddenly found that the driver's side window won't roll down, but I can hear the motor running. What could be the issue?
9Today, while washing my car, I noticed that all the left side windows have markings, but the three right rear windows don't. What's going on here? Did I accidentally buy a damaged car? I own a 2021 Subaru Outback flagship model.
10Does anyone know why the passenger side window switches in the ZS model are not working? Is there a switch somewhere that can control them? A picture would be great, thanks 🙏💡
