سلمان حريري
2024-11-24 20:28
Hi everyone, does the CC Shooting Brake have a place for spraying windshield washer fluid on the rear wiper? Is the windshield washer fluid for the front and rear wipers added together, or is there a separate washer fluid reservoir for the rear?
سعود عمار
سعود عمار2024-11-24 21:01
There's only one wiper fluid reservoir. Push the wiper lever all the way forward to spray the rear window.
The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
What could be the reason for the windshield wipers not spraying water? Can someone with experience explain this?
Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
My rear wiper can only spray water but doesn't move. What's the issue? Is the motor broken?
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Volkswagen Volkswagen CC
Volkswagen CCTBDGasoline & Petrol
