عبدالله حسن
2024-12-06 07:32
Does the playback sound of your original dash cam have any noise, like the hissing sound of old TVs with no signal, and it's so loud that it almost drowns out the conversation inside the car? Is this a common issue, or is it just me? 😰 Please help.
For a 2011 Volkswagen Phaeton with 130,000 kilometers, experiencing issues with the key frequently failing to unlock the doors or the car not detecting the key inside, along with a loud engine noise, here's what you can do: 1. **Key Issues:** - **Battery Check:** Start by checking and replacing the battery in your key fob, as a weak battery can cause these problems. - **Signal Interference:** Ensure there is no electronic interference around you when using the key. Sometimes other devices can disrupt the signal. - **Reprogramming:** If the issue persists, consider having the key reprogrammed by a professional. 2. **Engine Noise:** - **Oil Level and Quality:** Check the engine oil level and quality. Low or dirty oil can increase engine noise. - **Regular Maintenance:** Ensure regular maintenance is performed, including oil changes and tune-ups, to keep the engine running smoothly. - **Inspect Components:** Have a mechanic inspect the engine components like the timing belt, exhaust system, and other parts that might contribute to the noise. Regular maintenance and addressing minor issues promptly can help maintain the car's performance and longevity.
Is it noisy for people sitting in the car while driving on the highway? Specifically, when the boss is driving at high speed, is the exhaust sound loud inside the car during normal driving? Looking forward to your insights! 😊
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
How about adding an aftermarket sound system? Any recommendations? Also, what about dash cams?
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
Why is there no sound on the dash cam?
The turn signal sound is too loud. Is there a way to make it quieter?
Hi everyone, I'm a newbie here and I have a question. When you park your Panamera on a slope and put it in P, does it roll a bit and make a loud clunk sound when you release the brake? And when you shift from P to N, is there also a clunk sound? My new car makes a really loud noise. It's scary, I almost thought I got hit.
Volkswagen Volkswagen CC
Volkswagen CCTBDGasoline & Petrol
