Has anyone experienced the issue where the RPM doesn't drop after releasing the throttle on a Cayenne? Looking for solutions. 🙏
In normal mode, when coasting after releasing the throttle, the car jerks when the speed drops to 5 KM/h. Is everyone experiencing this too?
Has anyone experienced the compass not working after replacing the original head unit? Any solutions?
4At 45,000 kilometers, there's no issue with a heavy throttle, and there's no problem with a light throttle either. But when I press the throttle slightly harder, the issue arises, especially noticeable at 2000 RPM. There's no such problem when the car is cold, but once the water temperature reaches two bars, it comes back. It's really frustrating. Any advice? 🙏🙏🙏
5Has anyone experienced their car's tachometer suddenly jumping above 3000 RPM and then dropping back down while driving?
6When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
7When will it be released if it doesn't even look as good as the Sagitar?
8[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
9Has anyone experienced the issue where the RPM doesn't drop after releasing the throttle on a Cayenne? Looking for solutions. 🙏
10Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
