Has anyone experienced a metallic knocking sound when starting the 2024 Cayenne? I've been to the 4S shop several times but they couldn't find the source.
Isn't there an AUX port in this car? I've been looking for a while and couldn't find one.
I changed the transmission oil at 40,000 km at the 4S shop, and now at 100,000 km, I'm planning to replace it for the second time. I'm considering using Shell CVT transmission oil. Has anyone tried it? Is it okay to just clean the metal filter?
Has anyone found the battery guard for the 2024 model? I couldn't find it anywhere online.
4This car has been abandoned by the manufacturer, and Dongfeng Fengxing is about to go bankrupt. What should everyone do if they can't find a 4S shop? Do you usually get maintenance at the 4S shop?
5Is it better to buy Cayenne brake pads online or go to the 4S shop?
6Does anyone know how to maintain the transmission for the Pentium 8AT version? I've been asking the 4S shop for a long time, and they keep saying it's out of stock. Can I get it serviced at an external transmission repair shop? Just using gravity oil change, can other maintenance kits be sourced at external repair shops?
7Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
8Does anyone with a V40 have a source for chassis bushings? I want to buy them myself and then find a repair shop to replace them.
9Has anyone experienced a metallic knocking sound when starting the 2024 Cayenne? I've been to the 4S shop several times but they couldn't find the source.
10Why do all 4S shops say there's no 2024 HS7 with four-wheel drive?
