علي عباد
2024-07-21 00:33
Cayenne steering wheel noise: When the car is cold, there's no issue; it's very smooth. After driving for a while (around 1 hour), especially in hot weather, there's a squeaking noise when turning the wheel. Do any fellow car enthusiasts have the same issue? I saw on a social media platform that it might be the airbag clock spring?
سعود محمد
سعود محمد2024-07-30 23:12
The new car's front and rear wipers make noise in the rain. After randomly buying a domestic wiper, the problem was solved. Porsche's quality [I want to be quiet].
علي عباد
علي عباد2024-07-30 00:29
So does nobody else have this issue?
عبدله عمر
عبدله عمر2024-07-21 22:28
I had the same issue. Yesterday, I went to the 4S for maintenance and asked them to adjust it, but they didn't tell me the result afterward. Now I'm not sure what to do.
محمد سعيد
محمد سعيد2024-07-21 11:37
What does it look like specifically? Let's see if it's the same.
I have a 2009 Toyota Yaris 1.6 automatic. Recently, the car has been making strange noises. It sounds like a spring or shock absorber is out of place. Does anyone know what the issue might be? Is it serious?
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
There is a squeaking noise when the steering wheel of my 2008 Kia Sportage is turned all the way. What could be the problem?
After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
How can I fix the squeaking noise from the middle door when driving over bumps? Does anyone else have this issue with their car?
When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
Porsche Porsche Cayenne
Porsche CayenneAED 313,200 ~ 811,400Diesel & Gasoline & Hybrid & Petrol
