حسن لحود
حسن لحود
Apr 24
Why is it so hard for the temperature to drop after starting the air conditioner today?
أحمد نظيف
أحمد نظيف2021-05-04 12:05
First, use the external circulation to expel the hot air from the car, then turn on the air conditioner.
محمد طموح
محمد طموح2020-05-31 09:44
The air conditioner is blocked and won't cool down.
نايف طاهر
نايف طاهر2020-04-24 15:07
Whether the air conditioning compressor is turned on, after turning it on, it usually takes a few minutes to cool down. Otherwise, there might be an issue with the compressor, or it could be low on refrigerant.
خالد رأس
خالد رأس2020-04-24 14:58
First, turn on the AC, set the temperature to the lowest, set the fan speed to maximum, and adjust the airflow direction to face you. Then, activate the internal circulation. The temperature should drop quickly. If it doesn't, it might be due to low refrigerant or a faulty compressor.
2015 Subaru Outback with 50,000 km, the brake feels very hard when starting the car, but it's normal after starting. What could be the reason?
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
Why does it show high coolant temperature at startup? Unable to start.
New cars have dropped in price so much, why are used ones still so expensive?
Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
Renault Captur
Renault CapturOMR 4,700 ~ 7,000Gasoline & Petrol
