What's everyone's idle speed usually at? Mine's between 950 and 1000 RPM, is that high?
Whose car idles at 1000 RPM when warming up, and has anyone fixed it?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
4T8 idling at 1000 RPM, what's going on?
5What's the idle speed for the 2017 Volvo V40? Is mine at 900 a bit high?
6Why is my S40 idling at 1000 RPM, and how can I bring it down?
7When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
8Why is the idle speed around 600 to 700 RPM?
9The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
10After refueling my Jetta VS7 at the gas station, the idle speed tends to be high, around 1000 RPM. Then, during driving, the speed fluctuates. After driving for about ten kilometers, the idle speed returns to normal. Alternatively, if I turn off the engine and restart it, the idle speed also normalizes. I've tested this each time I refuel, and it's always the same situation.
