عبد العزيز خير الدين
2021-01-05 12:52
How long is the warranty for the transmission valve body?
خالد ستار
خالد ستار2021-01-05 13:01
Regarding the car's transmission valve body, under normal circumstances, it should be covered for 3 years or 100,000 kilometers. This information is usually specified in the manual that comes with the car after purchase.
How is the battery warranty? Is it a lifetime free replacement?
The 1.4T model keeps showing a fault light, and there's no 2nd, 4th, and 6th gear. The computer, valve body, and clutch have all been replaced, but the issue persists. How can this be resolved? Has anyone encountered this?
2010 Changan Yuexiang, experiencing body vibration at low speed and low RPMs. The symptom disappears at higher speeds. What could be the issue? Is it the valves or are the engine mounts worn out?
Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
How long is the body of the Hyundai i10?
How long is the battery warranty for BYD e2 non-first owners?
Has anyone experienced issues with the transmission solenoid valve on the URV?
The solenoid valve keeps breaking. How's yours doing?
Renault Renault Captur
Renault CapturAED 51,500 ~ 70,900Gasoline & Petrol
