ممدوح حسين
2020-05-25 10:58
How do you reset the maintenance indicator, and how much engine oil is needed?
محمد رمضان2021-06-05 09:34
Don't be misled by those unfamiliar with the Koleos. This car requires Renault's 0-20 specific engine oil for the Koleos. It needs 5.5 liters.
سعود رشيد2021-05-07 20:30
I don't know how these people answered, probably they don't even have this car. For the Renault Captur, 4.8-5L of oil is enough for an oil change.
أحمد نظيف2021-05-04 12:00
3.5 liters of engine oil
سلمان أنور2020-05-25 11:38
You'll need about 3.5 to 3.8 liters of engine oil. Just make sure the oil level on the dipstick is between the upper and lower limits. For resetting the maintenance light, just ask the technician to do it. It's a quick job with a computer, takes about two minutes.
What type of engine oil do you use during major maintenance?
How many liters of engine oil are needed for the maintenance of this car?
4How many liters of engine oil does a Lancer need for maintenance?
5How much monthly salary do you need to afford it? 🤦♂️
6How do I reset the trip meter after maintenance on a V40?
7How do you reset the maintenance light on a 2017 MG ZS?
8I've changed the oil. How do I reset the maintenance reminder?
9For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
10How much differential oil needs to be changed?
