راضي حسين
2020-10-10 10:43
Hey folks, my emission warning light was on for a few days, then it went off. Anyone else had the same issue? What could be the reason?
أحمد نظيف
أحمد نظيف2021-04-24 13:28
It might have happened accidentally.
خالد مكي
خالد مكي2020-10-30 16:07
It's normal, happened once.
علي حسن
علي حسن2020-10-10 11:11
If the engine warning light is on, it could be due to a sensor issue or poor fuel quality, both of which can trigger the warning light. However, to know the exact reason, you'll need to use a computer to check the fault codes. If the warning light is not on now, generally speaking, there's usually no problem.
What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
I have a 2012 model Jimny, registered in September 2013, currently at 46,000 kilometers. At the end of May, the engine warning light came on once. I used a diagnostic tool to reset it, but it didn't specify the reason. I had maintenance done on June 2nd, and the engine warning light appeared again the day before yesterday, but it disappeared yesterday afternoon when I went out. Does anyone know what might be going on?
Has anyone had the engine warning light come on? How did you deal with it?
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
Hey folks, got a low oil warning and the next day it started making noise. Even after adding 4 liters of oil, it's still the same. Any idea why?
Why is the emission warning light on and the steering wheel shaking when accelerating? Does anyone know?
Haven't driven my car for a few days. Almost fell asleep when my neighbor messaged me saying my car's hazard lights were flashing. Went downstairs and sure enough, they were. No alarm, just the hazard lights. Couldn't turn it off with the key, so I had to get in, start the car, and turn off the hazard lights to stop it. Really bizarre.
I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
Renault Renault Captur
Renault CapturAED 51,500 ~ 70,900gasoline & Gasoline
