راضي حسين
2020-03-14 22:43
Hey buddies! One time I braked hard and the gear shifted from D to N. Has this happened to anyone else? Is it normal? (;`O´)o
عبدالرحمن عوض
عبدالرحمن عوض2020-08-25 23:35
Even if you're braking randomly, it's unlikely to accidentally shift from D to N, right? Did you see the display on the dashboard change, or did the gear lever actually move from the D position to N? Do you have a habit of driving with one hand on the gear lever? Maybe when you braked, your arm bent and accidentally pushed the gear lever up?
عبدالرحمن خلدون
عبدالرحمن خلدون2020-03-14 23:03
This situation doesn't happen very often unless you slam on the brakes. However, even in such cases, it won't cause significant damage to the transmission or brake system, so you can rest assured.
The gear is constantly showing in N position. There's no response when shifting to A or reverse gear. Seeking advice from experts. What might be the issue?
Is it normal for the RPM to increase by 100-200 when shifting the FJ from D to N, and then continue to maintain the increased RPM?
Liberty shifting from D to N feels jerky.
The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
Why is there an impact when shifting from R to D gear?
Renault Renault Captur
Renault CapturAED 51,500 ~ 70,900Gasoline & Petrol
