can i use washing oil to clean the Mazda 6 or it will affect the polish?
What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
Does oil leakage from the engine hood of the 2014 Peugeot 301 affect its use?
4Does oil seepage from the engine cover of the 2014 Peugeot 301 affect its use?
5Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
6How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
7Can I use 5W-20 oil for an old Mazda with a 623 displacement that has run 300,000 kilometers? The 30 oil feels a bit thick. 😬
8I got scammed into replacing a new steering gear for my Mazda 6 due to an oil leak, and now the steering feels lighter. I'm not used to it.
9Will a damaged air resonance box affect the performance of a 2013 Mazda 6?
10Hey guys, what can I do if the headlights on my Mazda 6 are too dim?
