Why do they only use ternary lithium batteries?
Why are there only small cars and no trucks?
Why do you think the McLaren GT doesn't use the traditional family headlights?
4How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
5My E2, with a 47 kWh battery, charges up to 100%, but why does fast charging only add 35 kWh? I've already replaced the power battery due to the same issue, but the problem persists. Please help, it's urgent.
6How do I change the battery for the 2022 model car key? What type of battery does it use?
7Which company's battery does this car use?
8Is the battery of the 2020 ASX durable? Mine is only in its fourth year and it's already having issues with not starting and battery draining.
9Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
10Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
