Is the ternary lithium battery in this car using 811 or 523?
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
Why do they only use ternary lithium batteries?
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
4Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
5Is the ternary lithium battery in this car using 811 or 523?
6How do I change the battery for the 2022 model car key? What type of battery does it use?
7Can a used X have its battery replaced for free?
8Which company's battery does this car use?
9What brand of battery does Subaru XV use?
10Is the e2 the latest BYD electric vehicle platform, and does it use the Blade Battery?
