Is the portable charger for this car easy to use? Can you just use an extension cord to charge the car directly?
Can a home charger for the 2017 X90D charge the 2023 X Long Range?
I would like to ask if the fast charging for the Taycan can only be used at Porsche's official charging stations? Can outside charging stations provide fast charging? How is the charging speed?
4In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
5Can the Honor phone connect directly to the car system?
6Hey guys, if your car didn't come with a charging station, what charging stations are you using? Any recommendations for ones with good value for money?
7How long does it take to fully charge the E2 with a slow charger? The range is 405 km.
8Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
9Can you open the car door directly from the inside while driving, is it always like this?
10Hello everyone in the Leapmotor community, I have a question. Can you unplug the charging gun during slow charging at home? This morning at 6 o'clock, while I was sleeping and the car was charging, my father needed to use the car. He directly unlocked and unplugged the gun to drive away. This raises my doubts: Can the Leapmotor C11 pure electric model be directly unplugged during slow charging? First, does this operation pose any threat to personal safety? Second, will this affect vehicle safety? Third, will it impact the battery? If it's an incorrect operation, how should one correctly stop using the car during charging?
