نايف عباد
2024-04-01 23:17
I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
عمر إياس
عمر إياس2024-06-06 09:12
I've been a car owner for almost a year: When I first bought it, I took great care of it, charging slowly and avoiding fast charging. But now, I can barely reach 540 km on a full charge. Forget it, I'll just use it as needed. Even with the intense usage of ride-hailing, I haven't heard many people say the battery degrades to the point of being unusable.
علي تاج الدين
علي تاج الدين2024-06-05 10:06
By the way, when you charge, do you stay inside or outside the car?
علي تاج الدين
علي تاج الدين2024-06-05 10:05
The lower charging limit is correct, and the upper limit is set at the manufacturer-recommended 90%.
عبدالله نعيم
عبدالله نعيم2024-04-18 08:31
Shallow charge and discharge, 30-90%, occasionally (8-10 times) fully charge, like before a highway trip.
عبد العزيز زيد دين
عبد العزيز زيد دين2024-04-05 12:05
To protect the battery, avoid over-discharging and over-charging.
I'm curious if it's due to my driving habits? [Facepalm] Why is the fuel consumption of my NC quite different from what many people say? I feel like it's more than 10 liters per 100 kilometers. Some drivers can go 600 kilometers on a full tank, but with 100 kilometers on the highway, I only managed just over 300 with three-quarters of a tank. I spent 274 RMB on fuel, which works out to 11 liters per 100 kilometers. (Or is it because I used 92-octane fuel, haha?)
For a 12-year-old car that has already run 190,000 kilometers and is experiencing a lack of power when starting, it's generally recommended to use a high-mileage engine oil. High-mileage oils are specially formulated to help reduce oil consumption, minimize leaks and oil seepage, and reduce smoke and emissions in older engines. They also contain additives that help condition seals and protect worn engine parts. You might want to consider a 10W-40 or a 5W-30 high-mileage oil, depending on your climate and specific engine requirements. Always refer to your vehicle's manual or consult with a professional mechanic for the best advice tailored to your car's condition and needs.
Is the official capacity 37 kWh, but now it's only charging to 30 kWh? Could it be a battery issue?
It could be that the battery is weak, especially if it's been sitting overnight. Cold temperatures can also affect the battery's performance, making it harder to start the engine. You might want to check the battery charge and connections to see if everything is in good condition.
Is there anyone else waiting for the range extender version? This car really hits the spot for me. Just look at the Denza D9, selling around 10,000 units a month, with only about 500 being pure electric. You can see how few people can accept a pure electric MPV. Zeekr, please hurry up and release the range extender version. Also, offer a pure electric option so consumers have more choices. Sales will definitely go up.
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
