Can the C40 remotely turn on the air conditioning?
How to turn off the automatic air conditioning?
Has anyone picked up the C40? In this autumn weather, without using the air conditioning, how much does the range actually decrease?
4How much range does the C40 have with the air conditioning on in summer? And is the space very tight?
5How can I manually turn off the air conditioning? I always have to tap on the screen to turn it off.
6Does the EX3 Kungfu Bull support remote air conditioning control via a mobile app? Is there an option to modify it for external power discharge, and is it effective?
7Does your Santana's engine shake when you turn on the air conditioning for cold air?
8Why does the air conditioning keep turning on and off at idle in first gear?
9The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
10When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
