Where is the air conditioning blower of a 2011 Volvo C30, and how do you remove it?
Hey car enthusiasts, what brand of engine oil are you using for your Volvo C30? Which brand do you think is better?
How do I display the fuel consumption on the dashboard of a Volvo C30?
4How do you replace the air conditioning filter? Can someone explain it?
5Where do I remove the air conditioning filter on a Jeep Compass?
6The air conditioning filter for the 2011 Volvo S40 is typically located behind the glove compartment. To access it, you usually need to open the glove compartment and remove any screws or clips that hold the compartment in place. Once removed, you should be able to see the air filter housing and replace the filter.
7How to remove the rear seats of a Volvo C30?
8How to remove the air conditioning vent louvers?
9The air conditioning isn't cooling well. How do you guys usually fix this?
10Can the seats of the Supernova Pro be retrofitted with ventilation and an independent blower added for the rear air conditioning at the 4S dealership? It's too hot, and the air conditioning is really poor.
