علي صارم
2023-04-08 17:58
Have you ever encountered a situation where the car doesn't move in D gear, and you have to shift to 1st or 2nd gear to start moving?
The manual sunroof of the Haima S5 Youth Edition can't open. The motor is functioning properly, but it's stuck and won't move.
Hey folks, I have a question. My car can't shift gears. When the engine is off, the gear lever can move freely, but when the car is on, it's like something is blocking it, and it won't go into gear. It's a manual transmission, and I can't shift into any gear from 1 to 5 when the car is on. Does anyone know what the problem might be? Thanks 🙏🙏🙏🙏
What should I do if the small table inside my Multivan is stuck in the raised position and won't go down?
Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦‍♂️🤦‍♂️🤦‍♂️
What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
Volvo Volvo C30
Volvo C30TBDPetrol
