What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
The 1.4T model keeps showing a fault light, and there's no 2nd, 4th, and 6th gear. The computer, valve body, and clutch have all been replaced, but the issue persists. How can this be resolved? Has anyone encountered this?
4There is a buzzing noise while the vehicle is in motion, but I'm not sure where it's coming from. The mechanic thinks it's too much trouble to check and says it's fine as long as there are no fault codes in the car's computer.
5After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
6Engine shows fault code, acceleration is weak, what could be the reason?
7If your 2010 Suzuki Swift 1.5 automatic is still shaking after replacing the spark plugs, ignition coils, PCV valve, and EGR valve, there could be other issues at play. Some potential causes could be: - Engine mounts: Worn or damaged engine mounts can cause vibrations. - Fuel injectors: Clogged or malfunctioning fuel injectors can lead to engine misfires. - Throttle body: A dirty or faulty throttle body can affect engine performance. - Air intake system: Check for any leaks or blockages in the air intake system. - Transmission issues: Problems with the transmission can also cause vibrations. You may want to consult a professional mechanic to diagnose the issue more accurately.
8MG ZS intermittent engine fault code. It disappears and then reappears, how to deal with it?
9[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
10What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
