The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
Is it normal for the Volvo S40 2.0 with a six-speed dual-clutch to run at 3000 RPM when driving at 120 km/h on the highway?
Is the engine RPM high when driving at high speeds with the Ousheng 2.0 5-speed?
What's the idle speed for the 2017 Volvo V40? Is mine at 900 a bit high?
4Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
5What's going on with the Volvo C30 when you can't shift gears? It's stuck in the P position and won't move.
6Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
7Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
8When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
9The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
10After refueling my Jetta VS7 at the gas station, the idle speed tends to be high, around 1000 RPM. Then, during driving, the speed fluctuates. After driving for about ten kilometers, the idle speed returns to normal. Alternatively, if I turn off the engine and restart it, the idle speed also normalizes. I've tested this each time I refuel, and it's always the same situation.
