How do I set the C30 to Chinese? I can't figure out the central control.
How to change the dashboard language of a C30 to Chinese?
How do I adjust the seat height on the 2010 Mitsubishi Lancer 1.6L? It's different from the current models, and I can't figure it out.
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
4Liberty 2020 model, what's up with the EyeSight warning? Can't figure out the reason? How do you guys handle it?
5How do I set up the compass on the 2014 navigation model? I can't find the setting option. I switched to a big screen 360. Could the change in the central control be causing the compass to malfunction? Please let me know how to set it up.
6How do I set the C30 to Chinese? I can't figure out the central control.
7Does the central control screen support original car settings?
8How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
9Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
10After the central control was reset to factory settings, it shows that it can't connect to the network and can't enter the system.
