حموي محمد
2024-12-04 16:39
Has any car owner modified the front grille of the range extender car?
Comments( 6 )
محمد ضياء2024-12-05 22:59
I've been waiting for someone to develop a cover that you can just pop on. If you really need the air intake, just take it off. [I want to be alone]
نايف رحمن2024-12-05 21:21
I quite like Mazi's "I Want to Be Quiet".
محمد نايف2024-12-05 21:00
It's not an intake issue; it should be a problem with the range extender's cooling.
حسن حسن2024-12-05 11:09
I really want to apply a film to cover it up.
سعود عبد الناصر2024-12-04 19:02
If the engine hasn't been used for 10 years, you might as well patch it up like smoothing over a pockmarked surface. [I want to be alone]
حسن عل2024-12-04 18:26
You changed it, how does the engine intake air [I need some quiet time]
When will the extended range version be released?
It would be great if the EX30 had a range extender version.
I'm wondering how to modify the GA6. Any suggestions from fellow car owners?
4Has anyone here modified the grille emblem and rear emblem of their Koleos to black?
5Has any car owner modified the headlights? I asked at the shop and they said it needs to be changed to 16 lenses, 8 for low beam and 16 for high beam. I haven't seen any examples of such work, so I didn't dare to modify it easily. [Facepalm]
6Will there possibly be an extended-range version of the 009 in the future?
7Is there a range extender?
8Will there be a range extender version?
9Will there be an extended-range version????
10When will the extended-range version be released?
