Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
There is a bit of a jerky feeling when shifting gears, and it lacks power when accelerating. What's going on? I've already cleaned the fuel system and replaced the transmission assembly. #JetourX95
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
4I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
5Lately, I've noticed that when I start driving, the car stays in first gear until 2500 RPM and then suddenly shifts with a big jolt.
6Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
7MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
8Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
9Is optimizing the over-speed program helpful for the feeling of gear slipping during acceleration in the Outlander?
10Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
