عبدالله موجا بطاقة تعريف
Oct 23
How often should windshield wipers be replaced?
Comments( 8 )
محمد زيلاخ2024-10-25 14:15
I always hear a noise when scraping, and then I change it.
عبدالله عبد لطيف2024-10-24 00:10
If it doesn't clean properly, just replace it.
علي عباد2024-10-23 22:21
Replace the weatherstripping separately.
2
سلمان وحيد2024-10-23 19:16
I usually buy two pairs for 39.9 and replace them casually every few months.
عبد العزيز صالح2024-10-23 17:28
If it doesn't clean properly, just replace it. Poor quality ones last about three months, while good quality ones can last over a year.
فهد زبير2024-10-23 14:27
I haven't changed it for 3 years.
2
حسين أبو بكر2024-10-23 13:06
There is no set replacement cycle for wiper blades. Generally, if the blades are worn out and leave streaks, it's time to replace them, and they're not expensive. If it's just leaving a film on the glass, you might want to consider removing the oil film first.
أحمد حمد2024-10-23 10:56
If it doesn't clean well, just replace it.
How often should the battery of the 2018 Dongfeng Renault Koleos be replaced?
[Prayers] How often should I replace the car battery???
How often should brake pads be replaced?
4How often should the battery of a 2019 Changan Yuexiang manual transmission be replaced?
5How often should a car battery be replaced?
6How often should the fuel filter of a Mitsubishi ASX 1.6L be replaced?
7How often should the timing belt and accessory belt be replaced on your Santana?
8How often should the fuel filter of a 2019 Changan Yuexiang be replaced? Looking for advice online.
9How long can windshield wiper blades last?
10Why do windshield wipers always leave streaks and make noise?
