سلمان اشرف
Nov 6
How often should I replace my car tires? Mine have been used for five years.
[Prayers] How often should I replace the car battery???
How often should brake pads be replaced?
How often should a car battery be replaced?
4How often should the fuel filter of a Mitsubishi ASX 1.6L be replaced?
5How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
6How often should the timing belt be replaced? My car is over 9 years old with 81,000 kilometers on it. Do I need to replace the timing belt? Thanks to all the fellow car enthusiasts.
7How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
8Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
9Why are there grooves on one of the brake discs of a car that's been used for five years?
10I've been driving my RX300 for five years. I'm torn between switching to an electric car or continuing to drive it.
