سلمان اشرف
2024-10-08 16:49
How often should brake fluid be changed?
علي عباد2024-10-09 15:41
Changed at 48,000 kilometers.
أحمد زيد دين2024-10-09 11:55
40,000
عبد العزيز صالح2024-10-08 19:52
40,000 kilometers or 2 years. The brake fluid is quite cheap.
20
حسين أبو بكر2024-10-08 19:14
I followed the manual and changed it at 40,000 kilometers.
How often should brake pads be replaced?
How often should the gear oil be changed for the Rapid?
How often should differential oil be changed?
4How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
5How often should the transmission fluid be changed?
6How often should transmission fluid be changed?
7How often do you guys change brake fluid? Looking for advice!
8How often should the transmission oil be changed?
9Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
10How often should brake fluid be changed?
