Hello everyone, has anyone experienced noticeable shaking when the car is in D mode with auto-hold on? It doesn't happen in N or P mode.
Comments( 7 )
I bought a 280 Sharan in October 2017, and it has run 38,000 km. Recently, I've noticed that the car stalls and restarts twice when auto start-stop is active. It happens when I stop at a red light; the car auto-stops, then restarts, and soon after, it auto-stops again and immediately restarts. This doesn't happen very often, only twice this month, and otherwise, the car runs fine. Can anyone advise on what might be the issue? Should I take it to the dealership for a check-up?
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
4Hey everyone, does the 3rd gen Mini have auto hold?
5Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
6Seeking advice from fellow car owners: 1. Is it normal to feel a slight vibration in the steering wheel when the air conditioning is on? 2. When using the standard + B mode, there's almost no brake dive, but when the auto hold is activated, the brake dive is quite noticeable. Do you experience this too?
7Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
8Can the ECO mode be turned off when driving a 2023 Toyota Allion Elite in D gear? Also, is it true that the headlights can only be on auto and cannot be turned off completely?
9I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
10Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
