خالد دليل
2024-09-30 14:41
Hello CHR owners, what tire pressure do you usually maintain, around 2 point something? For summer and winter, I'd appreciate some guidance from fellow owners! I inflated mine to 2.6 the other day, is that a bit high?
Comments( 7 )
عمر منصور
عمر منصور2024-10-01 07:21
The manual suggests checking the tire pressure once a month. Just keep an air pump in the car.
عبد العزيز صالح
عبد العزيز صالح2024-09-30 23:45
In winter, it can be higher. 2.7 is no problem. In summer, 2.3-2.5 is fine.
20
عمر اميره
عمر اميره2024-09-30 21:39
I always shift at 2.5.
حسين أبو بكر
حسين أبو بكر2024-09-30 21:32
I'm sorry, the provided text is incomplete. Could you please provide more context or complete the sentence?
عبدالرحمن عباس
عبدالرحمن عباس2024-09-30 19:31
Summer 2.3 Autumn 2.4 Winter 2.5
حسن خليف
حسن خليف2024-09-30 19:01
In summer, don't set it too high. When the weather cools down, it's fine. I've always kept it at 2.5.
محمد زيلاخ
محمد زيلاخ2024-09-30 17:40
Daily 2.5, for comfort follow the manufacturer's recommendation, 2.3.
20
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
I'd like to ask fellow car owners, when you turn off the car and park it in P gear, does it move slightly when you release the brake? Mine has been doing this a lot lately.
Toyota Toyota CHR
Toyota CHRAED 86,900 ~ 102,900Hybrid
