Do you have any abnormal noises coming from the center console of your car? When in Drive (D) and holding the brake, there's a "dang dang dang" sound from the driver's center console. There aren't any issues in other gears.
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Does your MG One's center console have any unusual noises?
Do you have any recommended links for high-quality car weather strips? The original seals aren't holding up well in the desert.
4I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
5It's already 2024, but the latest model is still from 2022. Is this car going to be redesigned? There aren't any spy shots yet.
6To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
7Hey car enthusiasts, after parking and turning off the engine, without opening the door, I can hear a loud electric current noise from the dashboard/center console. Have any of you experienced this?
8Hi everyone, I'm thinking about replacing the center console in my Xiaozhi. Any recommendations?
9Is there anyone who has experienced rattling noises from the center console screen and the driver's side door when driving on uneven roads in the 2019 Taurus? It's driving me crazy!
10Do you have any abnormal noises coming from the center console of your car? When in Drive (D) and holding the brake, there's a "dang dang dang" sound from the driver's center console. There aren't any issues in other gears.
