نايف اشرف
نايف اشرف
Oct 26
Do you guys hear any noise from the passenger side? Once I pick up speed, there's a noise coming from there.
حسين مجدي
حسين مجدي2024-10-27 22:19
I have a noise coming from the trunk.
محمد قيس
محمد قيس2024-10-27 15:44
My car makes noise too. When I turn up the music, it just keeps making noise, but I'm too lazy to deal with it. As long as it runs, it's fine. It's been 2 years and 50,000 kilometers now. [I need some peace]
2
أحمد أكرم
أحمد أكرم2024-10-27 12:04
Is it the type that makes a sound when someone is seated and doesn't make a sound when no one is seated?
Does your Vitara make any noise when going over speed bumps? I feel like there's some noise coming from the brakes or suspension area in my car.
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
When driving at 60-80 km/h, I hear a buzzing noise coming from the front of the car. It gets a bit better when I speed up. I initially thought it was a bearing issue, but after replacing it, the noise is still there. What could be the cause? Could it be the belt, transmission, or something else? (The car has 130,000 km on it.)
Hey everyone, does anyone else have strange noises coming from the front passenger seat or the trunk? 🤔
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
Toyota CHR
Toyota CHRSAR 101,660 ~ 105,425Hybrid
