حسين حكيم
2024-10-06 20:40
After running and turning off the car, when I open the oil cap, there's a faint white mist coming out. Does this happen to you guys too?
أحمد أكرم
أحمد أكرم2024-10-12 12:18
No worries, if you don't open it, you won't see it. [Grin]
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
Is there pressure in your ASX's fuel tank? When I open the fuel tank, there's air coming out.
My 2021 model has run about 53,500 kilometers, and both rear tires are almost completely worn out! Which brand of tires are you guys switching to now?
Hey guys, when is the new 212 coming out? Why is there no news about it?
Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
How do I reattach the tether of the fuel cap on my 2012 model 308 if it has come off from the car?
I just bought a used 2016 Santana, and I'm trying to figure out how to lock the fuel tank cap. I realized it can be opened no matter what I do.
Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
Toyota Toyota CHR
Toyota CHRAED 86,900 ~ 102,900Hybrid
