فهد مراد
2023-11-19 15:42
In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
أحمد دل
أحمد دل2023-11-20 20:13
The biggest factor is temperature. If you can maintain the same temperature and road conditions but still notice a difference, then there's an issue. Otherwise, variations are within the normal range. Achieving a 1:1 range depends on many conditions.
عمر نايف
عمر نايف2023-11-19 20:27
The indicated mileage is based on your recent driving habits, and the rate at which the displayed mileage decreases is based on the current energy consumption. Factors like slope, load, and wind speed can greatly affect energy consumption, so when these objective factors change significantly from before, it can lead to a sharp drop in the displayed range.
محمد عباد
محمد عباد2023-11-19 19:32
That does seem a bit unusual. When you slow down and brake, there's no energy recovery happening, and it keeps warning that the brake and accelerator are pressed simultaneously. Could it be that the floor mat is blocking the brake? It's best to visit a service center to check if there's an issue with any system.
حسن كم
حسن كم2023-11-19 16:40
Due to weather conditions, the charging speed of this car significantly decreases when the temperature is below 25℃, and the energy consumption noticeably increases. I guess we'll have to wait until next summer.
Is the portable charger for this car easy to use? Can you just use an extension cord to charge the car directly?
How long does it take to fully charge the Z using fast charging?
What is the maximum charging power (kW) that the Z can reach with fast charging?
I would like to ask if the fast charging for the Taycan can only be used at Porsche's official charging stations? Can outside charging stations provide fast charging? How is the charging speed?
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
Have you ever experienced the charging process suddenly stopping halfway? I've encountered this several times recently. Sometimes it stops just after charging a few kilowatt-hours, other times it stops at 80% or even at 90%... I'm not sure what's causing it.
How long does it take to fully charge the E2 with a slow charger? The range is 405 km.
Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
How long does it take to fast charge the Song 160 km version? What is the charging power and how long can the maximum power be maintained?
