حسين محمود
2023-12-16 14:28
After the system upgrade, I noticed there's now a battery percentage display. The staff didn't clearly explain what improvements were made. Does anyone know?
Comments( 6 )
خالد ق
خالد ق2024-01-22 00:07
How to upgrade?
نايف عماد
نايف عماد2024-01-13 22:30
The 4S shop didn't upgrade for me [I want to be left alone].
عبدالله رامز
عبدالله رامز2024-01-04 11:40
The total battery capacity has also changed.
2
أحمد دل
أحمد دل2023-12-19 21:39
You can usually get 80% to 100% done in about an hour.
حسن كم
حسن كم2023-12-17 21:42
Another improvement is that the trickle charging speed after 90% has been increased a bit.
محمد عباد
محمد عباد2023-12-16 15:36
Improvement just means adding a percentage. 😄
I really want to know if the battery pack of this car can be upgraded later to improve its range? It's too short now. Is there anyone specializing in this?
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
It's over, right? Back then, those HiPhi car owners who blamed me were really smart, weren't they? You guys are just so clever. Ding Lei made a car like a cheap little runabout and convinced you it was better than a Ferrari, and you actually believed it. Now that Ding Lei has taken off with your money, are you still happy about it?
My relative gave me a 2006 Peugeot automatic 1.6L 307. A few days ago, it was running low on fuel (almost to the red line), and the range showed there were 60km left. Suddenly, it made a "ka" sound and everything stopped, showing something about "gearbox." After turning it off and restarting, it was fine, and adding fuel prevented the issue from happening again. Should I get it checked? The mileage was over 60,000 when I got it, and now it's at 88,000. Seeking advice from the forum experts.
Today I was driving my MG One and stopped at a red light. I put the car in park, and when the light turned green, I shifted to drive. Suddenly, the car system reported that the battery was dead and there was an engine fault code. The car wouldn't move even when I pressed the gas. After turning off the engine and restarting the car, it was able to move again, and the fault code disappeared. I went to a friend's repair shop to check, but they didn't find any issues. Since I was at the traffic light and the car behind kept honking, I didn't have time to take a picture. I'm a bit regretful about that. When I go to the 4S shop, I'm not sure how to explain it.
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
I didn't drive for two days, and when I started the car today, I noticed the engine warning light was on. For the first ten minutes or so, pressing the accelerator only increased the RPM, and the speed stayed below 20. After driving for about ten minutes, when I pressed the accelerator, there was a humming noise, and the speed gradually picked up. However, the fuel consumption display kept changing even when the car was parked or just started and not moving (or maybe I hadn't noticed this before). Can anyone advise what's going on? Has anyone experienced this before?
Does the G80 have any interior odors? I used to drive an XC60, and it didn't have any smell at all—the cabin was very comfortable. However, Volvo's soundproofing isn't great. I took a ride in a car-hailing service today, and there was an indescribable odor inside the car. Not sure if it was a plastic smell or something else, but even though it was faint, it made sitting inside uncomfortable. I don't know how the driver tolerates it. I test drove the G80 and noticed a bit of a smell, but it wasn't unpleasant. It definitely can't compare to a new Volvo. I'm curious if the smell will still be there after one or two months. With my previous XC60, even after being parked under the sun, there was no noticeable odor inside. Any G80 owners care to share their experience?
Hey car enthusiasts, has anyone experienced shaking during sudden acceleration? It shakes after driving steadily for a while, especially noticeable at high speeds. The 4S shop only cleared the previous driving habits, which improved slightly but didn't solve the root problem.
