محمد حكم
2024-10-12 14:56
Originally, a single action would complete the task, but now the rear and front passenger windows require three or four actions to complete, and you also have to look at the indicator on the screen. What's the design philosophy here? Does more complexity equate to a more premium feel?
عمر آسيا
عمر آسيا2024-10-13 08:30
Is it possible to have voice control?
Choosing your first performance car is an exciting decision! Here's a brief rundown of your options: 1. **2003 Subaru Impreza STI**: Known for its rally heritage, it's great for all-weather performance and has a strong AWD system. However, it might be older in terms of technology and features. 2. **2013 Toyota 86**: Offers a balanced rear-wheel-drive experience, known for its handling and driving fun. It's a bit less powerful but very engaging to drive. 3. **2014 Ford Fiesta ST**: A fun, nimble, and affordable hot hatch. It's smaller and great for city driving, with a lively turbocharged engine. 4. **2014 Volkswagen Golf GTI**: A well-rounded hatchback that combines performance with practicality. It's comfortable for daily driving and has a strong community and aftermarket support. 5. **2004 Mitsubishi EVO 8**: Another rally-inspired choice, with strong performance and an AWD system similar to the STI. It may require more maintenance due to its age. Your choice should depend on what you value most—whether it's all-wheel-drive performance, rear-wheel-drive dynamics, or a mix of practicality and fun. Also, consider maintenance costs, reliability, and availability of parts for these older models.
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
If you're considering the Jetour X70, there are a few things to keep in mind. Here are some pros and cons based on general feedback: Pros: 1. **Design**: The Jetour X70 is often praised for its stylish design and aesthetic appeal, which seems to be one of the reasons you're considering it. 2. **Space**: It typically offers a spacious interior, making it comfortable for families and long trips. 3. **Features**: The vehicle usually comes equipped with a range of features that enhance comfort and convenience. Cons: 1. **Manual Transmission**: If you're looking at the manual version, consider whether you prefer this over an automatic, especially in heavy traffic conditions. 2. **Brand Recognition**: Jetour might not be as well-known as some other brands, which could affect resale value and brand trust. 3. **Performance**: Depending on your expectations, the performance in terms of horsepower and Fuel economy might not match some competitors. Overall, it's important to weigh these aspects based on your personal needs and preferences. If possible, test driving both the Jetour X70 and Jetour Dasheng could help you make a more informed decision.
Today, while washing my car, I noticed that all the left side windows have markings, but the three right rear windows don't. What's going on here? Did I accidentally buy a damaged car? I own a 2021 Subaru Outback flagship model.
I experienced a similar issue with my steering column making noise and feeling stuck. The dealership suggested replacing it, but it's quite expensive, so I didn't go for it. How did you guys deal with this problem? Do you have any good solutions? My car is over three years old and has run more than 20,000 kilometers, and this issue has come up. I think there might be a quality issue here.
Choosing between the Volkswagen T-Roc and the Mazda CX-30 can be tough, especially when both second-to-top trims are appealing. Here are some points to consider: 1. **Performance and Handling**: Check which car offers the driving experience you prefer. Volkswagen is often praised for its solid performance, while Mazda is known for its sporty handling. 2. **Interior and Comfort**: Look at the interior quality and comfort. Volkswagen might offer a more classic design, whereas Mazda often has a more stylish and modern interior. 3. **Features and Technology**: Compare the features and tech offered in each model. Consider what’s important to you, like infotainment systems or safety features. 4. **Fuel Economy**: Consider the Fuel economy of each model if that's a priority for you. 5. **Brand Preference and Resale Value**: Sometimes, brand loyalty or resale value might influence your decision. Ultimately, it depends on your personal preferences and priorities. Test driving both might help you decide!
Toyota Toyota bZ3
Toyota bZ3AED 140,000Electric
