Automatic headlight switch and automatic wiper switch not working.
How do I turn on the headlights when unlocking the vehicle at night? The headlight switch is set to the auto position.
I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
The wipers aren't working, no response at all. What's the issue? I've only driven 7,000 kilometers.
4The headlights are not working, but the high beams are bright. Why is this happening?
5Today, I'm not sure what happened. The headlights and high beams are not working.
6Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
7The "Follow Me Home" function on the 2021 Jetour X90 headlights is not working. When you lock the car doors, the headlights do not turn on.
8Is your automatic wiper system working well? Sometimes it doesn't work properly.
9Automatic headlight switch and automatic wiper switch not working.
10The start-stop switch sometimes works, sometimes doesn't.
