Is the 2024 BRZ only compatible with 98 octane fuel?
Guys, does the RCZ only require 95 octane fuel?
Is the Scirocco only able to use 95 octane fuel?
Has anyone ordered the 2024 BRZ?
4Why can't I see the average fuel consumption on the 2024 Arrizo 5, only the instant fuel consumption? 🙂
5Is the 2024 BRZ only compatible with 98 octane fuel?
6Can the 2024 mid-range V60 connect to Huawei's HiCar, or is it only compatible with Apple's CarPlay?
7Has the 2024 BRZ solved the rubber issue?
8In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
9Hey folks, does anyone use 98 octane fuel? I filled up with a tank of 98 yesterday and noticeably felt the engine noise reduced. Is this just psychological? Let's discuss it! 😄
10Are you using 95 or 98 octane fuel?
