عمر إدريس
عمر إدريس
Dec 9
Is anyone else experiencing unstable idling with the new BRZ? Even without the AC on, whether the car is cold or warm, the gauge needle fluctuates noticeably.
Comments( 10 )
حسن مرشد
حسن مرشد2024-08-30 22:44
Are you going to the 4S dealership for the new car?
عبدالله زايد
عبدالله زايد2024-08-25 07:31
It's normal for a naturally aspirated 2.4-liter engine to achieve 235 horsepower, as it requires a high-angle camshaft, which inevitably affects idle stability. High-rev engines are like this. Many more extreme race cars don't even idle; they only run at high RPMs.
سلمان كم
سلمان كم2024-08-23 20:36
Fuel quality issues can be mitigated by using IPRON 98, as it might perform better. Adding fuel additives each time you refuel can also help alleviate the problem.
محمد اشرف
محمد اشرف2024-08-21 21:15
My Avalon too.
علي جل
علي جل2022-12-30 09:15
You bought the genuine product!
باسل عبدالرحمن
باسل عبدالرحمن2022-12-28 22:20
Do you guys feel the car shaking a lot when sitting on the seat?
عمر إدريس
عمر إدريس2022-12-21 20:00
I added two bottles of additive, and it stabilized at around 300 kilometers per tank. But later it didn't work anymore. It seems like it's an issue with our fuel quality, even though I always use 98.
فهد حسن
فهد حسن2022-12-16 12:34
It's normal. Some people's idle speed is 600 RPM... Mine is at least 800 RPM.
عبدالله زايد
عبدالله زايد2022-12-11 09:14
Congratulations on the genuine product! [Thumbs up]
علي شعبان
علي شعبان2022-12-10 10:17
Occasionally fluctuates by about 100 RPM. Mine does too.
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
Just got it, the engine idle speed fluctuates when cold. Any fellow car owners experiencing this?
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
Why is my 2018 1.6 manual transmission car having unstable idle when cold started?
Does anyone with a 2008 model experience the same issue? In the hot summer, whether idling or driving, the blower occasionally runs at a high horsepower, making a loud noise. It's more noticeable when idling and parked.
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
Has anyone experienced idle speed being sometimes high and sometimes low? When I'm waiting at a traffic light, sometimes it's 7500, sometimes 9500, and this is without the AC on. The last two times, right after refueling, the idle speed was 9500. Not sure what's going on.
When idling in place, the tachometer occasionally fluctuates slightly. What could be the issue, fellow car enthusiasts? On a flat road, when driving in first gear at idle, there is a noticeable jerk. The jerkiness becomes more pronounced when the air conditioning is turned on.
Subaru BRZ
Subaru BRZQAR 93,000 ~ 136,000Gasoline & Petrol
