Are there any fellow car owners who have installed a dashcam? I bought one, but the 4S shop said they don't know how to install it. Just wondering, does the BRZ only have the fuse box in the engine compartment? How do you all get the power?
Comments( 9 )
The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
Do I have to renew my insurance at the 4S shop? They said if I don't renew there, I won't get the lifetime warranty.
Can the 2020 T99 have a dashcam installed by oneself?
4How to install a dashcam?
5Are there any car enthusiasts who know how to install and remove fender flares? The work done by the 4S shop technicians is really rough.
6To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
7Where do you power your dashcam from? If you don't need parking monitoring, is it better to take power from the reading light, OBD, or the fuse box?
8Does not installing the electric pedal at a 4S shop affect the lifetime warranty? 💡
9When will the 4S shop have cars in stock?
10Does your car have a rattling noise in the timing belt area? I went to the 4S shop and they said it's nothing. 🤥🤥🤥
