عبدالرحمن عمار
2019-03-16 22:25
What could be causing the unpleasant odor inside the Bluebird? Do any other car owners have the same issue? Could it be from the window tint?
أحمد سلمان
أحمد سلمان2019-03-18 18:37
My one-year-old car still has an odor.
عبد العزيز هكيل
عبد العزيز هكيل2019-03-16 22:33
It's quite normal for a new car to have a strong interior odor. This is mainly because most of the materials inside, like leather and plastic, can emit smells initially. I recommend ventilating the car to help with this.
سلمان أنور
سلمان أنور2019-03-16 22:32
If there's a strange or unpleasant smell in a new car, it's quite normal. You can air out the car on a good weather day to help dissipate the odor. Additionally, you can purchase activated charcoal bags online and place them in the car.
عمر عيسى
عمر عيسى2019-03-16 22:27
It's actually normal for a new car to have some odors. The best way to remove these odors is to keep the vehicle ventilated to let them dissipate quickly. Additionally, you can use charcoal bags or purifiers to help eliminate the smell.
I have a question for fellow car owners: Do you maintain the leather in your car? If so, what products do you use and how often do you do it? Also, regarding window tint, I've heard that better quality tints are thicker. I'm experiencing a squeaking noise when opening and closing the windows. Do any of you have this issue?
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
It's a common issue. The big smell in your car during summer is usually due to the heat causing materials inside to release odors. When you turn on the air conditioning, it helps circulate air and reduce the smell.
Is there any other Coaster owner experiencing the same issue where the engine RPM fluctuates up and down while coasting in neutral?
During the rainy season, typically from April to August, the car doors cannot be opened from inside or outside, while they function normally at other times. Could it be that the lock mechanism is affected by moisture on rainy days? What might be the issue here? Experts, please help! Thank you!
When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
Is there anything other than a battery issue that could cause the auto start-stop to show the battery not fully charged on a three-year-old car?
17 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
What's causing the accelerator vibration in the 2017 Compass? Does anyone else have the same issue?
