My old Bluebird loses power and stalls every time I shift gears. What's going on?
2011 model of the Chery Tiggo 4WD automatic. Recently, while driving in D gear, it feels like it automatically shifts to neutral. The engine revs, but there's no power, and it takes several seconds to regain power! Seeking help from fellow car enthusiasts, what's going on???
My radio keeps losing power, could you tell me where the fuse box is?
There is a bit of a jerky feeling when shifting gears, and it lacks power when accelerating. What's going on? I've already cleaned the fuel system and replaced the transmission assembly. #JetourX95
4I have a 2009 Accent. Why does the car stall every time I press the clutch?
5What's going on with the Volvo C30 when you can't shift gears? It's stuck in the P position and won't move.
6Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
7My 10-year-old Honda City automatic car has noticeable shaking when I shift into reverse gear, but it's smooth in other gears. Can any expert comment on what might be the problem with my car?
8Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
9Why does the Ford Territory suddenly lose power and then accelerate again multiple times when normally accelerating to 60 km/h?
10My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
