How to deal with the issue of the reverse camera not responding on a 2005 Nissan Bluebird after starting, and where to connect the wiring?
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
The spare tire compartment always has water in it, what should I do? Is it because the drainage hole is blocked or is it an issue with the wiring of the installed reverse camera?
4Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
5If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
6Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
7Where can I buy the original wiring harness for the 2018 Nissan Patrol Middle East version?
8Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
9Hello everyone, does anyone know if there's a way to connect a dashcam to the luxury version of the Cyrus without wiring? Where's the best place to connect it?
10Has anyone with a HS7 encountered a camera malfunction where it shows a "cannot connect to camera" message?
